ASD Posted August 19, 2013 Report Share Posted August 19, 2013 不知道 Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 3325 MB CPU: AMD Athlon II X2 255 Processor Drive Info: C: 50.01 GB D: 104.01 GB E: 104.01 GB F: 104.01 GB G: 103.71 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
Config Posted August 19, 2013 Report Share Posted August 19, 2013 Are you getting a yellow line across the top of your webpage when you try to download?You can also try launching Internet Explorer in safe mode:Here’s how you can disable all addons/extensions and run IE8 without them:•Go to Start > Run•Type iexplore -extoff•Press EnterIf you can download while in safe mode, you likely have an add-in or toolbar interferring and can start weeding them out using Tools->manage addons and Tools->ToolbarsYou can also go to Tools->Internet Options->Advanced Tab and click on the reset button (but this will reset everything back to original)Let me know how you make out with these suggestions. Post back here if you have any questions. Link to comment Share on other sites More sharing options...
