e.germon Posted March 20, 2015 Report Share Posted March 20, 2015 I used Wise Registry Cleaner 4.41 in Command line with "wiseregcleaner.exe -a -all" and WRC ignores the file exlusion.dat. In exclusion.dat I have "HKEY_CLASSES_ROOT", "HKEY_LOCAL_MACHINE", "HKEY_USERS" and "HKEY_CURRENT_CONFIG" WRC delete keys in HKLM and HKCR in spite of exclusion.dat I use Windows 7 SP1 x86. MichaelOmita, Robertalgow, Ekbergwef and 6 others 9 Link to comment Share on other sites More sharing options...
e.germon Posted March 20, 2015 Author Report Share Posted March 20, 2015 I used Wise Registry Cleaner with command line in session administrator on Windows Server 2008 R2 with file Exclusion.dat. Exclusion.dat contains "HKEY_CLASSES_ROOT", "HKEY_LOCAL_MACHINE", "HKEY_USERS" and "HKEY_CURRENT_CONFIG" I used this command "WiseRegCleaner.exe -a -all" and i obtains multiple errors on Windows. When I clic on Computer in Start Menu, I obtain error message : "No program is associated with this file to perform this action. Install a program or, if it is already done, create an association in the Control Panel Default Programs." When i right clic on context menu on file reg or file ini, I obtain this message : "No program is associated with this file to perform this action. Install a program or, if it is already done, create an association in the Control Panel Default Programs." And i double clic on folder in explorer, I obtain also this message : "No program is associated with this file to perform this action. Install a program or, if it is already done, create an association in the Control Panel Default Programs." Thanks for your replies WIN-U2FCL412QPA 20-03-2015 170645.reg.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 24, 2015 Report Share Posted March 24, 2015 Hey e.germon, Thank you for your feedback.1, When you restore the registry, are these issues fixed?2, You said the file exclusion.dat contain "HKEY_CLASSES_ROOT", "HKEY_LOCAL_MACHINE", "HKEY_USERS" and "HKEY_CURRENT_CONFIG". But I checked your attached file (WIN-U2FCL412QPA 20-03-2015 170645.reg.txt), it contains "HKEY_LOCAL_MACHINE", "HKEY_USERS" and "HKEY_CURRENT_CONFIG". Can you export and send your exclusion file to me? Link to comment Share on other sites More sharing options...
e.germon Posted March 24, 2015 Author Report Share Posted March 24, 2015 I join my file exclusion.dat Despite the file exclusion.dat, wise registry cleaner in command line doesn' t use the file and delete the exclude keys. Exclusion.dat.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 25, 2015 Report Share Posted March 25, 2015 Your exclusion file is correct. Which version do you use? I use wise registry cleaner 8.42 to test, import your exclusion file, and used this command "WiseRegCleaner.exe -a -all", it works well, doesn't clean "HKEY_CLASSES_ROOT", "HKEY_LOCAL_MACHINE", "HKEY_USERS" and "HKEY_CURRENT_CONFIG" Link to comment Share on other sites More sharing options...
e.germon Posted March 25, 2015 Author Report Share Posted March 25, 2015 I use Wise Registry Cleaner 8.41, version 8.42 isn't available. When user is member of users groups, the exclusion.dat works but when the user is member of Administrators group, the exclusion.dat doesn't works on Windows 7 x86 SP1 and Windows Server 2008 SP2 and Windows Server 2008 R2 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 25, 2015 Report Share Posted March 25, 2015 Okay, I see. Wisecleaner products don't support multi-user, the config file is only effective with current user. So, user A change the WRC settings, when user B log in with his own account, the WRC settings is the old, different with user A. Link to comment Share on other sites More sharing options...
e.germon Posted March 25, 2015 Author Report Share Posted March 25, 2015 File config.ini and Exclusion.dat doesn't change when the user log in session because, I use a ps1 script who use WRC in command line. In Windows 7, when I log with administrator loggin, it ignores exclusion.dat Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 26, 2015 Report Share Posted March 26, 2015 Please tell me how many accounts do you have in this Windows 7 system?what account do you log in, when you set up the exclusion list?what account do you log in , When you use command line to open WRC? Link to comment Share on other sites More sharing options...
e.germon Posted March 26, 2015 Author Report Share Posted March 26, 2015 I have 3 account in Windows 7 (one admin and 2 users) I log in with command line and exclusion.dat with 3 account. I have a script ps1 at the start of the session in "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup" In admin session, file exclusion.dat doesn't work Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 27, 2015 Report Share Posted March 27, 2015 Can you show me your ps1 script file? Link to comment Share on other sites More sharing options...
e.germon Posted March 27, 2015 Author Report Share Posted March 27, 2015 I attach my ps1 script. CleaningWRC.ps1.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 30, 2015 Report Share Posted March 30, 2015 Hey, Can you use the portable version to try again? The config file of portable version is saved in the same folder of the program. Link to comment Share on other sites More sharing options...
e.germon Posted March 30, 2015 Author Report Share Posted March 30, 2015 Hello, I tested WRC 8.42 (portable version) in command line with exlusion.dat and config.ini. In Windows 7 with useraccount member of Administrators group ignores the file exclusion.dat and delete keys in HKLM and HKCR. Thanks for your answers config.ini.txt Exclusion.dat.txt Link to comment Share on other sites More sharing options...
