erickeloi Posted November 17, 2014 Report Share Posted November 17, 2014 eu cliko para abrir varios progamas e simplesmente esses programas não abram Obs:O Problema começou depois de atualizar o windos translated from portuguese unknown I click to open various programs and these programs do not simply open Note: The problem started after updating Windows Operating system:Windows 7 Home Basic (32 bit) Service Pack 1 System root: C:Windows Available physical memory: 1643 MB CPU: AMD E-450 APU with Radeon HD Graphics Drive Info: C: 456,59 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted November 17, 2014 Report Share Posted November 17, 2014 Download and run System Update Readiness Tool for Windows 7 for x64-based Systems (KB947821) [May 2014] From an elevated command prompt, launch (Windows installation cd could be necessary): sfc /scannow Wait till it finishes (15-50 minutes).If the final result is equal to Windows Resource Protection did not find any integrity violations or equal to Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch this command: copy %SYSTEMROOT%\Logs\CBS\CheckSUR.log %userprofile%\desktop\CheckSUR.txt After it, you should find checkSUR.txt on your desktop: post it here.Instead if the final result of the SFC TOOL is equal to Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch both the previous command in the code above AND also this command: copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt && findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txt After those two commands, you should find three files on your desktop: checkSUR.txt, cbs.txt and SR.txt: post here the checkSUR.txt and the sr.txt.If the last command won't work, try these (one by one): copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txt How to run an elevated command prompt for Windows vista/seven usersOne of these three methods:- click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear- click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear- click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear Link to comment Share on other sites More sharing options...
