xilolee Posted October 2, 2016 Report Share Posted October 2, 2016 Hi WiseCleaner_Admin and WiseTeam guys!I've already reported these (little) problems via email. Some of the portable versions create folders and store files in %appdata%:was ----> C:\Users\USER\AppData\Roaming\Wise Auto Shutdown\config.iniwpu ----> C:\Users\USER\AppData\Roaming\Wise Uninstaller\config.ini --- wpu_uninstall.log --- *.reg --- *.file --- *.file.list --- *.png wvc ----> C:\Users\USER\AppData\Roaming\Wise Video Converter\config.iniwgb ----> C:\Users\USER\AppData\Roaming\Wise Game Booster\run.txt --- config.ini --- plgame.dfg --- ub.lstwc365 --> C:\Users\USER\AppData\Roaming\Wise Euask\tipIds.iniwdc ----> C:\Users\USER\AppData\Roaming\Wise Disk Cleaner\UpdateInfo\ They should create those files inside their own program folders. WSM correctly shows my memory manufacturer name (NANYA) BUT it doesn't show the Manufactor string (maybe is manufacturer more correct?) in hardware monitor, memory (between speed and serial number).It probably wants the Manufacter string inside the Italian.ini (and also inside the other languages files). Vice versa, the Manufactor string in hardware monitor, graphic card is present, BUT it doesn't show my graphic card manufacturer name (INTEL). MichaelRob, orieptate, mamaligadoc and 7 others 10 Link to comment Share on other sites More sharing options...
