Posted
重新開機後,整個WIN 7的桌面圖示變大,下面的工具列也是變成大圖示,已經嘗試過調整螢幕解析度,但沒有用
translated from chinese
Screen
After rebooting, the entire WIN 7 desktop icon becomes larger, the following toolbar icon also become large, have tried to adjust the screen resolution, but to no avail
System root: C:Windows
Available physical memory: 8111 MB
CPU: Intel® Core i5-4440 CPU @ 3.10GHz
C: 195.21 GB
E: 270.45 GB
Internet Explorer: 11.0
Posted
通常,桌面图标的大小通过设置DPI就可以实现,且重启系统也不会失效,除非你安装了系统保护/还原软件,当系统重启后会恢复到一个自定义的初始状态。
Typically, the size of the desktop icons can be achieved by setting the DPI, and reboot the system does not fail, unless you install a system to protect / restore software, when the system restarts will return to the initial state of a custom.
