tipstir 14 Posted September 26, 2014 Report Share Posted September 26, 2014 Some features always seem to be not set to default. These should be the default and already check. The attached shows you what I mean. Even with V3.2.3 thru V3.2.5 it's always the same. Either the wont stick or by default you have it setup that way to be unchecked. Also Sun Java should be check I use it but it's always unchecked. Should be also address too. Thanks in advance. AppeptGause 1 Link to post Share on other sites
donut 62 Posted September 28, 2014 Report Share Posted September 28, 2014 Hi there, We'd like to tell you that we didn't set more items be be checked due to the different users with their different settings. Thanks! Link to post Share on other sites
tipstir 14 Posted October 1, 2014 Author Report Share Posted October 1, 2014 Last 3 on the list are more common since everyone has home router and attached more than one 1 PC too on the network side. That rest are more widely used. There is one more under apps called Sun Java part of Java should be noted that highly used if your going to run flash applets like facebook games or any flash streaming like you tube. Link to post Share on other sites
