Posted
Hello,
when I click on Start/System Control Panel and try to open it the windows explorer crashes and restarts itself.
I looked it up in the logs:
Beschreibung
Pfad der fehlerhaften Anwendung: C:\Windows\explorer.exe
Problemsignatur
Problemereignisame: APPCRASH
Anwendungsname: Explorer.EXE
Anwendungsversion: 6.1.7601.17567
Anwendungszeitstempel: 4d672ee4
Fehlermodulname: ntdll.dll
Fehlermodulversion: 6.1.7601.17725
Fehlermodulzeitstempel: 4ec4aa8e
Ausnahmecode: c0000005
Ausnahmeoffset: 0000000000018e3d
Betriebsystemversion: 6.1.7601.2.1.0.768.3
Gebietsschema-ID: 1031
Zusatzinformation 1: 0c08
Zusatzinformation 2: 0c083a2eb3a51eec4341378553fd8549
Zusatzinformation 3: 1c3c
Zusatzinformation 4: 1c3c1b68377d6567a03cbde3f4c66b96
Weitere Informationen über das Problem
Bucket-ID: 53479960
How can I fix this?
Thank you
System root: C:\Windows
Available physical memory: 3959 MB
CPU: Intel® Core i3 CPU M 370 @ 2.40GHz
C: 200,05 GB
E: 203,59 GB
F: 177,78 GB
Internet Explorer: 10.0
Posted
Do you remember that if this issue occurs after the installation of that program?
Hello Sir,
no I don't know. So uninstalling every application on the PC is not really an option.
Maybe there is a way to create a logfile you could analyse?
Posted
hi,
You can try this way:
please run Wise PC 1stAid, click the the 7th icon (Lame Internet Surfing ) to disable the third-party plug-ins.
If it still not work. Make the error displayed again, then find the folder, c:\users\your name\Appdata\Local\CrashDumps, send the *.dmp file to us.
Posted
Thank you.
I had to do some google reasearch to find CrashDumps Folder, since the feature is disabled by default.
Windows Vista and Windows 7
The following steps enable automatic crash dumps on Windows Vista SP1 and Windows 7:
1) Open RegEdit
2) Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error Reporting
3) Under Windows Error Reporting, create a new registry key named LocalDumps.
If Plex Media Server crashes after this, you will find a new dump file under %LOCALAPPDATA%\CrashDumps.
hi,
explorer.exe.8372.zip
Posted
Hi,
We have checked the attachment,  your system have lost some dll files: ntsdexts.dll , uext.dll , exts.dll , ext.dll
But those dll files are not belong to  system. Maybe they belong to  Debugging Tools for Windows®.
Have you installed it? If yes, please try to re-install it.
Posted
Hello,
thank you Sir.
Yes I have installed the Debugging Tools for Windows®.
But I installe dit after the problem started, so I doubt it has anything to do with it.
But I will remove it.
How do I fix the lost dll files?
