Samuel Posted August 8, 2013 Report Share Posted August 8, 2013 a program is trying to read an empty memory location. The program is AIRGCFG.EXE Link to comment Share on other sites More sharing options...
WiseCleaner Posted August 8, 2013 Report Share Posted August 8, 2013 Hi, I guess your system is Windows XP SP3. Go to Start Menu----Run, then type Msconfig.exe, click OK, and select the Startup tab. Find AirGCFG.exe in the list and uncheck the box next to it. This will stop the utility running on startup if you're already using Windows' Wireless Network Feature to configure your Wireless Adaptor. If needed, the program can still be run manually via the Start Menu. Link to comment Share on other sites More sharing options...
