Mehdi 0 Posted February 15, 2014 Report Share Posted February 15, 2014 some files are corrupted Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 503 MB CPU: Intel® Pentium® 4 CPU 2.80GHz Drive Info: C: 17.58 GB D: 24.41 GB E: 34.68 GB Internet Explorer: 6.0 Link to post Share on other sites
UCanFixIt 339 Posted February 15, 2014 Report Share Posted February 15, 2014 Your image is not visible. See: How to Post Screenshots You can also try running sfc /scannow from an elevated command prompt and see if that fixes your unknown issue. However, if none of the above work for you, then... Link to post Share on other sites
