amutlu30 Posted February 14, 2014 Report Posted February 14, 2014 Ekranım zaman zaman çok rahatsız edici bir göz kırpma olayı sergiliyor. Sorunun bir malware olabileceği yazıyor ancak bir türlü çözemedim. Baxen iyileşiyor gibi oluyor ama sonra yeniden başlıyor. Çok rahatsız edici !!! Lütfen yardım.... Operating system:Windows 7 Ultimate (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 2046 MB CPU: Pentium® Dual-Core CPU E5300 @ 2.60GHz Drive Info: C: 97,56 GB D: 200,43 GB Internet Explorer: 11.0
UCanFixIt Posted February 15, 2014 Report Posted February 15, 2014 Translated: My screen from time to time very disturbing event showcases the blink of an eye. Writes could be a malware problem but could not figure out. Bax is like the healing, but then it starts again. Very annoying!! Please help me .... Hello, Your exact message is getting lost in the translation but I'm guessing you think you are infected with some variant of the BAX malware. With that said, I would recommend you go here for guided assistance to properly detect, identify, and remove the resident malware: Am I infected? What do I do? Good luck, UCanFixit
