UZER Posted February 6, 2014 Report Posted February 6, 2014 не открывает приложение антивирус пишет,что ПК заражён сканирование показало,что ПК чист Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 2047 MB CPU: Intel® Celeron® CPU E1400 @ 2.00GHz Drive Info: C: 31,25 GB D: 201,64 GB Internet Explorer: 8.0
UCanFixIt Posted February 6, 2014 Report Posted February 6, 2014 No application opens antivirus says that PC is infected scan showed that the PC is clean Your post is somewhat confusing; in that, you say your AV software detects malware but when you do an AV scan, using the same AV software, it says your PC is clean? Please provide more detail to clarify your issue or go here for assisted malware removal: http://www.bleepingcomputer.com/forums/f/103/am-i-infected-what-do-i-do/
