uhl Posted February 2, 2014 Report Posted February 2, 2014 Instead of symboles in Certain programs as well as for instands the map in google map´s aren not displayed correctly Instead of the symbol a little icon with a red X is shown. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 511 MB CPU: Intel® Pentium® M processor 1600MHz Drive Info: C: 33,84 GB G: 465,76 GB Internet Explorer: 8.0
UCanFixIt Posted February 2, 2014 Report Posted February 2, 2014 I'm guessing those are XP system icons; yes? If so, you can try using TweakUI to rebuild/restore those default system icons. However, you also mentioned "certain other programs" so there may be more to this story than meets the eye. if so, see my signature for help in posting your complete issue properly: http://www.winhelponline.com/blog/repair-icons-windows-xp-using-tweak-ui/ The above suggestion is based on the assumption that your issue has not been caused by a malware infection.
