donut Posted January 24, 2014 Report Posted January 24, 2014 Hi there, Are you still complaining about short life of the laptop battery? Stop complaining please and let’s know some tips using that you can increase the life of the laptop battery. 1. Eject all the devices if not in use like USB, Pen Drive etc. 2. If you used the CD/DVD for data storing, avoid it. Use your hard disk to store the data. CD/DVD takes more power. 3. Off your Bluetooth, Wifi, and other sharing options. 4. Clean the battery terminal regularly. 5. Lower the brightness of your screen to the lowest level you're okay with. 6. Avoid using the background programs. 7. Use laptop in cool place or have an AC to keep the laptop temperate cool. 8. Hibernating is better than standby mode on a laptop.
