Vasudeva Posted January 21, 2014 Report Posted January 21, 2014 Los iconos de programas como Malwarebytes, Wise Care, WDC, etc. no se muestran, a diferencia de otros como iTunes, Mozilla Firefox, McAfee security Scan Plus. Windows fue recientemente instalado. Operating system:Windows 7 Ultimate (32 bit) System root: C:\Windows Available physical memory: 1535 MB CPU: Intel® Celeron® CPU 2.80GHz Drive Info: C: 39,06 GB D: 109,98 GB Internet Explorer: 9.0
WKK Posted January 22, 2014 Report Posted January 22, 2014 Hi Vasudeva, Please try to fix the issue with 1stAid first. If 1stAid can not resolve this problem ,Please check the installation directory of these programs,Whether there is an executable program in installation directory. such as Wise care 365,it's default installation directory is C:\Program Files\Wise\Wise Care 365.In this directory,WiseCare365.exe is the executable program. You need reinstall these programs if the executable program lose,
