borceanuiulian Posted January 6, 2014 Report Posted January 6, 2014 This webpage is not available Opera could not load the webpage because antenaplay.ro took too long to respond. The website may be down, or you may be experiencing issues with your internet connection. Check your internet connection. Check any cables and reboot any routers, modems, or other network devices you may be using. Allow Opera to access the network in your firewall or antivirus settings. If it is already listed as a program allowed to access the network, try removing it from the list and adding it again. If you use a proxy server... Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server: Go to the Opera menu > Settings > Change proxy settings... > LAN Settings and deselect "Use a proxy server for your LAN". Operating system:Windows 7 Ultimate (32 bit) System root: C:\Windows Available physical memory: 2047 MB CPU: Intel® Celeron® CPU 420 @ 1.60GHz Drive Info: C: 76,23 GB Internet Explorer: 9.0
UCanFixIt Posted January 6, 2014 Report Posted January 6, 2014 I can access antenaplay.ro without issue. It could have been down when you tried to access it originally so try again.
