Mickel Posted December 1, 2013 Report Posted December 1, 2013 every page ie opens has an error of some type all the pages have an ! inside a yellow triangle. web pages load slow or not at all Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 2047 MB CPU: Intel® Pentium® D CPU 2.80GHz Drive Info: C: 149.05 GB Internet Explorer: 8.0
Linkin Posted December 2, 2013 Report Posted December 2, 2013 Do you still get the error message after resetting IE8 to Default settings or even reinstalling IE8 ? When you installed other browsers, were there any additional optional ticky boxes which installed other apps with the download ? If any boxes are already ticked and you have be vigilant to see what else is being included in any downloads and untick them first before clicking on Next or Install. then restore to a point prior to its installation to see if that resolves this issue and then reinstall Chrome if you still want it - if the restore resolves the IE8 problem. Resetting to default/reinstalling IE8 usually resolves bugs Try the instructions below: Tools>Internet Options, Advanced tab, uncheck "Display notification about every script error". IF you find it is being checked again when you restart IE, one of your Addons (SpySwat toolbar for one) is turning it back on. The setting is used by web developers to debug their web sites. Bad Addon developers have forgotten to remove it when publishing their addons.
