What shoud we do when CPU temperture anomalies
Q: the weather is getting hotter and hotter, my CPU temperature reaches 70 ° c or so, is this normal? If not working properly what to do with it? My CPU is 1.3GB.
Answer: in General, the CPU temperature is over 30 degrees higher than the ambient temperature that should be normal. AMD CPU Thunderbird fever in particular relatively large. In theory ,The Thunderbird work properly under the 80-degree heat, but preferably below 60 degrees is safer.If your CPU temperature reached 70 degrees,that is a little too high, you can be sure that is caused by fan cooling capacity that is not very good. It is best for getting a good certified fan by AMD, and properly installed.
Link to comment
 Share
