Hendra 0 Posted November 8, 2013 Report Share Posted November 8, 2013 thank you for the solution. The way I've tried before, but failed. I do not believe for a second try. is there any way to repair the Flash Player that is already installed previously so that it can be easy to update without any problems? I am from Indonesia. Operating system:Windows 8 Pro (32 bit) System root: C:\Windows Available physical memory: 1014 MB CPU: Pentium® Dual-Core CPU E5500 @ 2.80GHz Drive Info: C: 58,25 GB D: 174,28 GB Internet Explorer: 10.0 Link to post Share on other sites
Adam 1 Posted November 8, 2013 Report Share Posted November 8, 2013 Try this way:open the Internet Explorer---the menu bar "Tools"---Internet Options-Security---------custom level security settings "under ActiveX controls and plugins" 5th "Download unsigned ActiveX controls" choose "prompt"---OK! Refresh the page that you want to install (because the use of the software is not passed Microsoft logo certification, in SP2, by default it is not allowed to install such a program, the solution forStart-Control Panel-system-hardware. Drivers have a "driver signing" option, after the opening. Select the first item: ignore-install the software anyway and don't ask for my advice. )2, open the Internet Explorer---the menu bar "Tools"------Internet---custom options – security level all to enable all disabled.3, open the Internet Explorer---the menu bar "Tools"------Internet Options Advanced options select "allowed to run and install the software, even if the signature is not valid"4, open the Internet Explorer---the menu bar "Tools"---Internet Options-Security------trusted site added to the site (note the HTTPS to http)Question evaluation thank youHere is a pictrure Pls review it. Link to post Share on other sites
