Hendra 0 Posted November 8, 2013 Report Share Posted November 8, 2013 thank you for answaring. The latest version i just plug-in, while the acrivex can not be installed on my computer. Operating system:Windows 8 Pro (32 bit) System root: C:\Windows Available physical memory: 1014 MB CPU: Pentium® Dual-Core CPU E5500 @ 2.80GHz Drive Info: C: 58,25 GB D: 174,28 GB Internet Explorer: 10.0 Link to post Share on other sites
Adam 1 Posted November 8, 2013 Report Share Posted November 8, 2013 1:use a special uninstall tool to uninstall previous Flash plugin for Flash . 2: power off and on again, restart after you install Flash plug-in, be sure to close your browser during installation, installation done, restart the computer. 3:Flash plugin, there are two, a browser is IE kernel, another browser is IE kernel. Installation should be clear or the installation useless. 4: if it's not on the highest version or upgrade your browser to reload the browser. 5: the above method doesn't work out with the related Web Shield or network shield repair. 6:Flash installation, access to the site and do not have, you open up the IE--tool to manage add-ins to see whether it is Shockwave Flash Object Flash plug-in. Link to post Share on other sites
