Kevin 0 Posted November 8, 2013 Report Share Posted November 8, 2013 今天在安裝avast防毒軟體,不知為何安裝不完全,導致無法刪除,並且也無法從解除安裝程式那邊移除,然後原本想從再次安裝方式,結果卻說上次安裝不完全,因此無法重新安裝,檢視日誌出現下述訊息,可以麻煩告訴我該如何解決這個檔案,感激不盡。 06:06:38Infoinstcont[3856,3164]-- 06:06:38Infoinstcont[3856,3164]2013/11/08 06:06:38 START: Avast installer/updater 06:06:38Infoinstup[3856,3164]Command: '"C:\Program Files\AVAST Software\Avast\setup\Sfx\instup.exe" /sfx /sfxstorage:"C:\Users\kevin\AppData\Local\Temp\_av_iup.tm~a01144" /edition:1 /prod:ais ' 06:06:38Infoinstup[3856,3164]CPU: Intel® Core i5-3230M CPU @ 2.60GHz,4 06:06:38Infoinstup[3856,3164]OS: Windows 8 ver 6.2, build 9200, sp 0.0 x64 06:06:38Infoinstup[3856,3164]Memory: 20% load. Phys:4194303/4194303K free, Page:4194303/4194303K free, Virt:2008840/2097024K free 06:06:38Infoinstup[3856,3164]Running module version: '9.0.2007.172' 06:06:38Infoinstup[3856,3164]Loading Proxy settings 06:06:38Infoinstup[3856,3164]Proxy-Type: 'no proxy' 06:06:38Infoinstup[3856,3164]Proxy-Authorization: 'no authentication' 06:06:38Infoinstup[3856,3164]Proxy-Port: '8080' 06:06:38Infoinstup[3856,3164]Proxy-Name: '' 06:06:38Infoinstup[3856,3164]Proxy-User: '' 06:06:38Infoinstup[3856,3164]Proxy-Pass: '???' 06:06:38Infoproductstate[3856,3164]Loading product state 06:06:38Infoproductstate[3856,3164]Guid = 117045ac-3e9e-4849-8f60-e64b457f2f1a 06:06:38Infoproductstate[3856,3164]Persistent Guid = 117045ac-3e9e-4849-8f60-e64b457f2f1a 06:06:38Infoproductstate[3856,3164]ProductId = ais 06:06:38Infoproductstate[3856,3164]Edition = 1 06:06:38Infoproductstate[3856,3164]Load part info: product.parts.current 06:06:38Infoproductstate[3856,3164]Part 'jrog2' = 'jrog2', 2248, 1383878029 06:06:38Infoproductstate[3856,3164]Part 'program' = 'prg_ais', 2007, 1383836451 06:06:38Infoproductstate[3856,3164]Part 'setup' = 'setup_ais', 2007, 1383836429 06:06:38Infoproductstate[3856,3164]Part 'vps' = 'vps_win32', 319883010, 1383878036 06:06:38Infoproductstate[3856,3164]Load part info: product.parts.latest 06:06:38Infoproductstate[3856,3164]Part 'jrog2' = 'jrog2', 2248, 1383890060 06:06:38Infoproductstate[3856,3164]Part 'program' = 'prg_ais', 2007, 1383890060 06:06:38Infoproductstate[3856,3164]Part 'setup' = 'setup_ais', 2007, 1383890060 06:06:38Infoproductstate[3856,3164]Part 'vps' = 'vps_win32', 319883010, 1383890060 06:06:38Infopartinfo[3856,3164]SetInstalled: Part package part-prg_ais-7d7.vpx is installed. 06:06:38Infopartinfo[3856,3164]SetInstalled: Part package part-vps_win32-13110702.vpx is installed. 06:06:38Infopartinfo[3856,3164]SetInstalled: Part package part-setup_ais-7d7.vpx is installed. 06:06:38Infopartinfo[3856,3164]SetInstalled: Part package part-jrog2-8c8.vpx is installed. 06:06:38Infoinstupcore[3856,3164]PkgLoadProductInfo: product GPB was successfully loaded. 06:06:38Infosimutex[3856,3164]Checking for the mutex ownership. 06:06:38Infoservers[3856,3164]Server definition(s) loaded for 'C:\Users\kevin\AppData\Local\Temp\_av_iup.tm~a01144\servers.def': 29 (maintenance:0) 06:06:38Infopkgproduct[3856,3164]LoadPartInfo: program = prg_ais-7d7 returned 0x00000000 06:06:38Infopkgproduct[3856,3164]LoadPartInfo: setup = setup_ais-7d7 returned 0x00000000 06:06:38Infopkgengine[3856,3164]LoadLatestProdAndParts: product file 'prod-ais.vpx' was successfully loaded. 06:06:38Infopkgengine[3856,3164]LoadLatestProdAndParts: part file part-prg_ais-7d7.vpx was successfully loaded. 06:06:38Infopkgengine[3856,3164]LoadLatestProdAndParts: part file part-setup_ais-7d7.vpx was successfully loaded. 06:06:38Infopkgproduct[3856,3164]LoadPartInfo: jrog2 = jrog2-8b9 returned 0x00000000 06:06:38Infopkgproduct[3856,3164]LoadPartInfo: vps = vps_win32-13110100 returned 0x00000000 06:06:38Infopkgengine[3856,3164]LoadLatestProdAndParts: product file 'prod-vps.vpx' was successfully loaded. 06:06:38Infopkgengine[3856,3164]LoadLatestProdAndParts: part file part-vps_win32-13110100.vpx was successfully loaded. 06:06:38Infopkgengine[3856,3164]LoadLatestProdAndParts: part file part-jrog2-8b9.vpx was successfully loaded. 06:06:38Infoinstupcore[3856,3164]PkgLoadProductInfo: product GPB was successfully loaded. 06:06:38Infosimutex[3856,3164]Checking for the mutex ownership. 06:06:39Infofilehlp[3856,3164]OpOnReboot: Direct delete of file 'C:\Users\kevin\AppData\Local\Temp\aswSetupOffers.def' successfully performed. 06:06:39Infoguiwizard[3856,3164]Setup gui was successfully started. Operating system:Windows 8 (64 bit) System root: C:\windows Available physical memory: 8071 MB CPU: Intel® Core i5-3230M CPU @ 2.60GHz Drive Info: C: 683.29 GB F: 931.51 GB Internet Explorer: 10.0 Link to post Share on other sites
Adam 1 Posted November 8, 2013 Report Share Posted November 8, 2013 Just try Wise Program Uninstaller to unload it . Link to post Share on other sites
