Posted
Dear madam,
I have proxy server problem in Internet Explorer 10.I want you to reset it at once.
Thanks and regards.
Anil
.png
Operating system:Windows 8 Pro (64 bit)
System root: C:\Windows
Available physical memory: 4028 MB
CPU: Intel® Pentium® CPU B950 @ 2.10GHz
C: 78.03 GB
D: 107.42 GB
E: 112.54 GB
Internet Explorer: 10.0
Posted
Solition one: try WPA of Wise Care 365  If Can't
Solution two:
1. Quit all programs that are running.
2. click "start", then click "run". In the "open" box, type' regedit,' and then click "OK".
3. in Registry Editor, locate the following subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\9.0\Common
Note this registry key applies to "applies to" section lists all versions, does not vary depending on the version of. If you are running 32-bit Office systems on 64-bit versions of Windows, you will need to use Wow6432Node HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\9.0\Common\Internet.
4. in the "Edit" menu, point to "new", and then click "".
5. the new subkey named "Internet".
6. ensure that the selected "Internet" subkey. In the "Edit" menu, point to "new", then click "DWORD value". Add the following registry value:
Value name: ForceShellExecute
7. double-click "ForceShellExecute", and then "value data" is set to 1. Click "OK".
8. in the "registry" menu, click "exit".
