BRUXO Posted November 3, 2013 Report Posted November 3, 2013 DEMORA EM INICIAR E CONECÇÃO COM A REDE DE INTERNET
Linkin Posted November 4, 2013 Report Posted November 4, 2013 There is a possibility that some third party programs installed on the computer is causing the delay in accessing the internet I would suggest that you perform clean boot and check. To help troubleshoot error messages and other issues, you can start Windows by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts. After you have finished troubleshooting, follow these steps to reset the computer to start as usual: a) Click Start, type msconfig in the Start Search box, and then press ENTER. If you are prompted for an administrator password or for confirmation, type your password, or click Continue. c) On the General tab, click the Normal Startup option, and then click OK. d) When you are prompted to restart the computer, click Restart. If you tried all the steps above and got no results, please don't hesitate to contact us and tell us more details about your PC.
