copia original do window 7 ultimate
mensagem dizendo que a copia nao é origina do windows 7 ultimate
System root: C:\Windows
Available physical memory: 3549 MB
CPU: Intel® Celeron® CPU E3300 @ 2.50GHz
C: 368,01 GB
E: 97,66 GB
Internet Explorer: 11.0
Link to comment
  1. Open your system.
  2. And go to your run command.
  3. Now to go to the run command just press the start button and there you can find a search bar and writer there CMD.
  4. Now after writing CMD there you will see that it shows CMD option.
  5. Just right click on that and select run as administrator.
  6. Remember that you have select CMD option by running it as administrator.
  7. After that when it opens up the command prompt just write a command- “SLMGR –REARM” on that.
  8. After giving this command just press enter.
  9. It will take few minutes and after that it shows you this prompt which is given by script host.
      10. Reboot your PC.
     Thanks.
Link to comment
 Share
