Posted
My Toshiba Laptop Satelite doesn't shut down. It will log off quickly but but it doesn't shut down at all. I hope their is a simple fix. By the way I love you program's it works incredible. I have used it on my computer at work and it runs sweet.
Posted
Hi,
Try this, in the power option (control panel) and in one of the tabs there is an option called "turn APM (advanced power management) on", check it.
 Hope it helps.
Good luck!
