Keith Posted October 6, 2013 Report Share Posted October 6, 2013 开电脑有问题,start window 过后只有黑幕还有mouse,请你帮帮我,谢谢 Operating system:Windows 7 Home Premium (64 bit) System root: C:\Windows Available physical memory: 2047 MB CPU: Intel® Core2 Duo CPU T6570 @ 2.10GHz Drive Info: C: 74.52 GB D: 206.96 GB H: 465.73 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted October 8, 2013 Report Share Posted October 8, 2013 Black screen might be caused by many reasons. 1. Make sure that your system is legal copy; 2. Make sure the power connection between displayer and host is correct and fine; 3. Did the computer too hot at that time? 4. Make sure the displayer in good condition, wasn't damaged causing that problem; 5. Check the CPU, Graphics Card, DDR, reinsert or replace if they are needed; ......Even unstable power might cause that. So you need to tell us what did you do caused that problem happen to fix it. Link to comment Share on other sites More sharing options...
