viktor Posted October 4, 2013 Report Share Posted October 4, 2013 время от времени комп зависает Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: F:\WINDOWS Available physical memory: 2039 MB CPU: Intel® Celeron® CPU 560 @ 2.13GHz Drive Info: C: 97,17 GB F: 51,87 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted October 5, 2013 Report Share Posted October 5, 2013 1. There might has virus or malware causing it. If so, use antivirus to kill the virus; 2. Too hot when it running might cause it as well, take it to other cooler place; 3. Unstable power, use voltage regulator can resolve this problem;4. The running program are too big causing freezing, if so, you might need to upgrade your pc configulation and system;5. The pc is too old, too much dust exist there causing short out; 6. The capacitor of main circuit has aging issue, it need to be changed or repaired....... Link to comment Share on other sites More sharing options...
