Posted
To be honest w/ you, I don't really know, but here's pt1 of my SW list.
Operating system:Windows 8 Pro with Media Center (32 bit)
System root: C:\WINDOWS
Available physical memory: 3071 MB
CPU: Intel® Core2 Duo CPU E7500 @ 2.93GHz
C: 465.76 GB
Internet Explorer: 10.0
Posted
Hi,
1. Please first uninstall the programs you installed before the issue occured, maybe you can check the installation time and uninstall the latest several programs.
Please check if this situation still occures.
2. If the first method does not work, please disable all IE plug-ins and check if this issue still occurs, if not, that is means one of the IE plug-ins has caused this issue. You can test one by one until you find out the program that caused the issue and then disble it.
Thanks.
