mainara Posted September 24, 2013 Report Share Posted September 24, 2013 toda vez que eu ligo o computador aparece uma janela que eu nao consigo fechar informando que o programa nao pode ser iniciado porque esta faltando o icuuc51.dll, para que eu tente reinstala-lo para resolver o problema , na janela esta escrito psafesystray.exe-erro do sistema Operating system:Windows 7 Home Basic (64 bit) Service Pack 1 System root: C:\windows Available physical memory: 1909 MB CPU: Intel® Core i3 CPU M 380 @ 2.53GHz Drive Info: C: 178,00 GB D: 266,29 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 25, 2013 Report Share Posted September 25, 2013 Hi, You can run Wise Program Uninstaller to uninstall the program "PSafe Protégé" , then restart system. If this operation can solve your problem, you can re-install the latest version of "PSafe Protégé", or install Microsoft Security Essentials. Link to comment Share on other sites More sharing options...
