Wise_EPL Posted September 24, 2013 Report Posted September 24, 2013 My System Properties Protection icon is still a white sheet of paper. How do I fix this? Operating system:Windows 8 Pro with Media Center (32 bit) System root: C:\WINDOWS Available physical memory: 3071 MB CPU: Intel® Core2 Duo CPU E7500 @ 2.93GHz Drive Info: C: 465.75 GB Internet Explorer: 10.0
april Posted September 25, 2013 Report Posted September 25, 2013 Hi, Please fisrt try the 1st solution in Wise PC 1stAid. If it does not work. Please follow the instruction below. Go here: http://www.stardock....s/iconpackager/ and get the trial version of IconPackager, install it, use it to switch to any icon package, then switch back (if you want to) the standard windows icons. Thanks!
