dagodm Posted September 22, 2013 Report Share Posted September 22, 2013 when i run wise care pro 365..., the common cleaner ....I can rerun it immediatly again and it will still find log files in system.... and will say privacy risk exist.... even though the privacy tab wont show any.... whats going on? Operating system:Windows 8 (64 bit) System root: C:\windows Available physical memory: 3550 MB CPU: AMD A6-4400M APU with Radeon HD Graphics Drive Info: C: 585.86 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 23, 2013 Report Share Posted September 23, 2013 Hi, Privacy in Common Cleaner and privacy in Privacy Propector, they are different. After you run Common Cleaner then immediatly run it again, it will find log files, this is normal. When you run Common Cleaner, other programs are running too, delete its log files, it will create a new log ifle soon. Or, some log files is protected, wise care 365 cannot delete them. So, when you run Common Cleaner again, it will find some log files. Link to comment Share on other sites More sharing options...
