iroc8 Posted September 21, 2013 Report Share Posted September 21, 2013 I have an old icon from a file that has been deleted a long time ago. Now I can't get rid of the icon because it says there is no file. Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 16375 MB CPU: Intel® Core i7 CPU X 980 @ 3.33GHz Drive Info: C: 919.56 GB D: 11.85 GB E: 931.51 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 22, 2013 Report Share Posted September 22, 2013 You might try this way, in 'Search' box of computer 'Start', search a folder names 'GPEDIT.MS ', then 'User Configuration','Administrative Template', 'Desktop', 'Remove Computer icon on the desktop'. Link to comment Share on other sites More sharing options...
iroc8 Posted September 22, 2013 Author Report Share Posted September 22, 2013 Apparently that's not working. When I do a search for that folder I get two references in a music folder for webpages both referring to a Windows 2003 installation. Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 22, 2013 Report Share Posted September 22, 2013 Please make a screenshot about your issue to further your solution. It should contains the dead icon and that prompt message. Link to comment Share on other sites More sharing options...
