iako933419_MSI Posted September 4, 2013 Report Share Posted September 4, 2013 用了你們最後一個 修改遊戲執行速度太慢 使用後 我的音效程式卻被說沒有了 可以請問 怎麼用回來嗎 Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\windows Available physical memory: 1644 MB CPU: AMD E-350 Processor Drive Info: C: 273.63 GB D: 182.42 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 5, 2013 Report Share Posted September 5, 2013 You means you clicked the last icon in Wise PC 1stAid? It will disable all third-party services. You can find out your audio service in: click Start---type Services.msc and press Enter, find out your audio service and set its startup type as Automatic And you can refer to this topic:http://forum.wisecleaner.com/index.php?/topic/174-how-to-modify-the-startup-type-of-services-automatic-manual-disabled/ Link to comment Share on other sites More sharing options...
