sudheeranpallath Posted August 25, 2013 Report Posted August 25, 2013 when am shut bown in my computer is showing auto insaletion running,,,,what happen,? Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3959 MB CPU: Intel® Core i5 CPU M 480 @ 2.67GHz Drive Info: C: 451.01 GB Internet Explorer: 9.0
Config Posted August 26, 2013 Report Posted August 26, 2013 Hi Plz don't worry. It's normal. You can modify the settings by following the steps below: Open Windows Update by clicking the Start button . In the search box, type Update, and then, in the list of results, click Windows Update. In the left pane, click Change settings. Under Important updates, choose the option that you want. Under Recommended updates, select the Give me recommended updates the same way I receive important updates check box, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
