ron Posted August 23, 2013 Report Posted August 23, 2013 windows will not update. Always failure message about installer problem Operating system:Windows Vista Home Basic (32 bit) Service Pack 2 System root: C:\Windows Available physical memory: 894 MB CPU: AMD Athlon 64 X2 Dual Core Processor 4200+ Drive Info: C: 139.40 GB D: 9.65 GB Internet Explorer: 9.0
Config Posted August 26, 2013 Report Posted August 26, 2013 Plz try this: Run the System File Checker tool (SFC.exe). To do this, follow these steps: Open an administrative Command Prompt window. At the command prompt, type sfc /scannow, and then press Enter. After the scan is finished, try to install updates again.
