chammie Posted June 21, 2015 Report Posted June 21, 2015 ie web page will not open, all I get is a blank page and address bar Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:windows Available physical memory: 5621 MB CPU: AMD A6-3650 APU with Radeon HD Graphics Drive Info: C: 931.41 GB Internet Explorer: 11.0 Ekbergwef 1
WiseCleaner Posted July 1, 2015 Report Posted July 1, 2015 1, Please check your Internet connection, whether it works well 2, You can try to reset IE to default settings. Open IE -> Tools -> Internet options -> Advanced, click Reset button, tick the option 'Delete personal settings', then click Reset 3, If step 2 cannot solve the problem, you can disable IE then Enable IE to try. Open Control Panel -> Programs -> Programs and Features -> Turn Windows features on or off, deselect Internet Explorer 11, click OK to save settings, you will be asked to reboot system. When you restart PC, open Control Panel -> Programs -> Programs and Features -> Turn Windows features on or off, tick Internet Explorer 11, click OK to save settings, you will be asked to reboot system again. 4, Open IE to check whether you can open a site
