[Solved - Win7-SP1-x64] icons are missing in devices and printers. totally blank
System root: C:\Windows
Available physical memory: 6038 MB
CPU: Intel® Core i5-2410M CPU @ 2.30GHz
C: 581.42 GB
Internet Explorer: 10.0
Link to comment
Try this way:
Click Start-----type services.msc in search box, press Enter, stop Bluetooth Support Service, set its startup type as Automatic, restart system.
thx for responding, unfortunately when i try to enable Bluetooth Support Service a dialogue box pops up and says , " The system cannot find the path specified and has been that way for close to a year now but the problem I'm having just started recently. Really stumped
Link to comment
Hi,
1, Click Start-----type services.msc in search box, press Enter,  set those 2 services's startup type as Automatic, restart system. (just set its startup type, do not need to start it)
  Print Spooler Service
2, If you still receive the message "The system cannot find the path specified", click this do download  Bluetooth support service and Print spooler service, unzip the archive and run the enclosed REG file.
3, Registering the DLLs
   Click Start---type CMD in search box-----right-click cmd.exe----click Run as administrator.
   type regsvr32 "%programfiles%\internet explorer\ieproxy.dll" and press Enter
   when finished, you will see this message.
4, Fixing the XML Registration
Download msxml6.zip, unzip the archive and run the enclosed REG file. This should restore the missing MSXML6.DLL registration entries.
Restart Windows and check if Devices and Printers opens correctly.
Link to comment
 Share
