icehart.tw Posted May 25, 2015 Report Posted May 25, 2015 電腦開網頁及程式還是很慢耶... translated from chinese: Open web pages and computer programs is still very slow yeah ... Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:WINDOWS Available physical memory: 3325 MB CPU: AMD Athlon II X4 640 Processor Drive Info: C: 65.01 GB D: 200.02 GB E: 200.73 GB Internet Explorer: 6.0
云淡风轻 Posted May 26, 2015 Report Posted May 26, 2015 建议升级到Win 7 64位的系统吧,4GB内存足够了。系统架构的原因,xp运行某些大型程序会很吃力。 Recommends upgrading to Win 7 64-bit systems now, 4GB of memory is enough.The reason the system architecture, xp run some large programs will be very difficult.
云淡风轻 Posted June 2, 2015 Report Posted June 2, 2015 升级windows 7 很简单1,google搜索win7光盘镜像,有很多资源,各国语言的都有,是.iso后缀不要下载所谓的优化过,或者精简的,系统容易出问题,不稳定。下载windows原版的2,用刻录工具,将光盘镜像做成系统光盘,通过光驱引导就可以升级安装win7 了。3,安装完成后,需要输入license code来激活,这就需要money购买了。当然,也有其他不需要money的方法,google 有很多结果 (你懂的,这个方法就不详述了) Upgrade windows 7 is very simple1, google search win7 CD image, there are a lot of resources, the national language of all, is a suffix .isoDo not download so-called optimized or streamlined, system vulnerable, unstable. Download original windows2, with the Burn tool that will make the system CD disc images, boot drive can be upgraded through the installation of win7.3. After the installation is complete, you need to enter the license code to activate, which requires money buying.Of course, there are other methods do not need money, google there are many results (you know, this method is not detailed)
