Posted
請問
為什麼我的電腦沒辦法正常開機?
開機就直接進入安全模式,F8設定正常開機也沒辦法。
麻煩各位解答,謝謝
translated from chinese
Not boot
Excuse me
Why does my computer can not boot?
Boot straight into a safe mode, F8 is no way to set the normal boot.
Trouble you to answer, thank you
Operating system:Windows 7 Professional (64 bit) Service Pack 1
System root: C:windows
Available physical memory: 8011 MB
CPU: Intel® Core i5-3230M CPU @ 2.60GHz
C: 135.36 GB
D: 97.75 GB
E: 214.84 GB
Q: 17.58 GB
Internet Explorer: 11.0
Posted
Because one of your drive has crashed. You need to find which drive crashed and uninstall the drive and then your PC will can boot with normal mode.
Run "msconfig" go to "boot" (may be boot.ini) and unchecked safeboot, reboot your PC, now you can boot with normal mode, but I guess you may get a blue screen with some error message, when this time you can find which drive crashed, or you can upload your dump file and we can help you to find which drive crashed.
