I delete avg files from wise search, but when I do a search again it re appear. Help please.
System root: C:Windows
Available physical memory: 4095 MB
CPU: Intel® Core2 Quad CPU Q8200 @ 2.33GHz
C: 447.37 GB
D: 397.87 GB
Internet Explorer: 11.0
You will need to uninstall AVG, not simply remove its files.  You should go to the AVG website, Support, and search for precise instructions as to how to remove AVG and all its remnants.  Some anti-virus products require a two-step un-installation.  AVG may require that their removal tool if the Add/Remove programs does not successfully uninstall it.  Here is a link to the AVG support site:
https://support.avg.com/supportArticleView?urlname=How-to-uninstall-AVG&l=en_US
Good luck.  Hope this helps.  Have a great day.
Regards,
-Phil
