jaisherring Posted August 3, 2013 Report Posted August 3, 2013 dear sir, I am not able to install some applications such as Adobe 11 etc as windows prompts \" window installation service is not available. kindly advise solution. [the windows installation service 3.1 is also not installaling] sincerely Jai sherring Operating system:Microsoft Windows XP (32 bit) Service Pack 2 System root: C:\\WINDOWS Available physical memory: 1526 MB CPU: Intel® Celeron® CPU 540 @ 1.86GHz Drive Info: C: 19.53 GB D: 19.53 GB E: 35.45 GB Internet Explorer: 8.0
terry Posted August 5, 2013 Report Posted August 5, 2013 Hello, Please follow the following steps to fix the issue. 1. Press "Win+R" or "start - run". 2. Type "gpedit.msc" to open Group Policy Object Editor 3. Go to "Local Compture Policy - Computer Configuration - Adiministrative Templates - Windows Installer - Disable Windows installer". 4. Double-click "Disable Windows Installer". 5. Change the settings to "Disable" and click "OK" button to save the changes. 6. Reboot your PC. Enjoy,
