Posted
The driver for the sound card disappears after pc shutdown. I re-install it and I have sound again. Shut down, and it\'s gone....no sound anymore. It\'s a sound blaster card, and the driver is one that came with my Win XP home addition. Any ideas? Other than wiping the hard drive and re-installing XP?
Posted
Hello,
Looks you installed some restore or system protect software. Please check your programs, if you find the software, you should to disable or uninstall it.
