Posted
Не устанавливаются ни одна из пробных версий антивирусников!Пробывалкасперского и нод 32.выдают одну и туже ошибку
System root: C:\WINDOWS
Available physical memory: 1788 MB
CPU: AMD Sempron M120
C: 49,81 GB
D: 99,24 GB
Internet Explorer: 8.0
Posted
 Make sure  all operations are right  when you operate in the safe status of Windows or incorrect the installment of Windowstaller.
Because the fix file of NOD32 is applied to the format MSI .So you must open the related service so that you can go on further installment.
Operations as  below:
One,Right-click of My PC
Two,Click "manger and applied 'service
Three,find 'Windows Installer' then double click
Four,open the dialog box of "personlize"
Five,in the column of Starting Trpe choose the Tab "Automatic"
Six,Click the Tab"avtivate" under the column of Service Status"
The last step ,click the tab"Applied "of Windows Installer
If still failed  that needs Re-installment of the sofaware of Windows Installer. After that that might be Ok .
