youngdollar Posted November 5, 2013 Report Posted November 5, 2013 my laptop says you should consider replacing your battery Operating system:Windows 7 Professional (32 bit) System root: C:\Windows Available physical memory: 1979 MB CPU: Intel® Pentium® Dual CPU T3200 @ 2.00GHz Drive Info: C: 70.92 GB D: 78.03 GB G: 0.10 GB Internet Explorer: 8.0
Adam Posted November 6, 2013 Report Posted November 6, 2013 One, Pls find the same model of laptop batteries try, in both directions, there may be battery is broken, there may be power supply management chip is broken, battery is broken you can buy power management chip is broken that is in trouble and in need of repair. Two, Pool cell aging appears damaged. May be caused by the forced disconnect the power, also which may be your regular battery-powered, rechargeable batteries normal aging damage many times. (We recommend you replace battery battery group).
