alkhafaji Posted October 30, 2013 Report Posted October 30, 2013 السلام عليكم اخواني الاعزاء الخبراء في مجال الكومبيوتر لدي مشكلة متكررة هو تعليق نظام الوندوز فجأة ولا يرجع للعمل الا بأطفاء اللابتوب من زر الاطفاء بالضغط المستمر (أطفاء غير نظامي ) لان اللابتوب يعلق نهائيا ولم يعد يعمل الا بعد اطفاءه Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3982 MB CPU: Intel® Core i5-3210M CPU @ 2.50GHz Drive Info: C: 63.79 GB D: 97.66 GB E: 97.66 GB F: 143.49 GB G: 63.06 GB Internet Explorer: 10.0
Adam Posted October 31, 2013 Report Posted October 31, 2013 Firstly When you finished system installment you must be surely about all the hardwares was attahced with the proper drive How to make sure all drives were installed ? 1.Back to PC desktop 2.Right click of the icon'My Pc' 3.Click icon'Properties' 4.Click icon 'hardware' 5.click icon'deice mangement' If you find yellow mark under the position of the hardware it shows that your pc is in urgent need of the related drive .That will limit and block some functions of your PC. Secondly some important system files missing Regarding this situation if you can't find missing files or cause much trouble it is better for you to Re-install system Of course the key solution is based on actual situation analysis this is only as your reference.
