Posted
при загрузке с флэшки компьютер пишет Verifyng DMI Pool Data..............................Boot from USB disk failed status (000000333 ) Gtrl+Alt+Del
Operating system:Microsoft Windows XP (32 bit) Service Pack 2
System root: C:\WINDOWS
Available physical memory: 2047 MB
CPU: AMD Athlon 64 X2 Dual Core Processor 5000+
C: 34,25 GB
D: 198,62 GB
E: 0,01 GB
Internet Explorer: 6.0
Posted
You means that bootup system from USB disk failed?
1, Make sure the USB bootup system is already.
2, Make sure the moterboard can identify the USB disk.
3, Startup system, press Delete key to run BIOS setting. (Maybe F2 or other keys)
4, Advanced tap or Bootup tap, select USB device as first bootup device.
5, Save settings and reboot system.
