donut
How to speed up Windows Explorer?
Hi there,
   Still feel bothered by the slower display load time of Windows Explorer? You will get rid of this issue after reading the following tips below.
Speed up the display load time of Microsoft Windows Explorer by disabling the feature that allows you to search for network printers and folders. By default each time Windows Explorer is opened it will attempt to locate any network printer or folder on your computer network. If your computer is not on a network or you have no network printers, folders, or shares disable this option by following the below steps.
1.      Open  Windows Explorer
2.      Click the Tools drop down menu and then Folder Options
3.      Within the Folder Options tab click the View tab
4.      Uncheck "Automatically search for network folders and printers"
