Flavio Posted August 2, 2013 Report Share Posted August 2, 2013 I have the malware Safesaver in my computer. It is not on add/remove programs. And my anti-virus is not removing it. I appreciate any help to remove it. Link to comment Share on other sites More sharing options...
WiseCleaner Posted August 2, 2013 Report Share Posted August 2, 2013 1, Remove toolbars, plugins, extensions, add-ons Internet Explorer and Mozilla Firefox users: Go to TOOLS and then click MANAGE ADD-ON, From there, select Extensions, Toolbars and remove the SafeSaver Plugin if found. Google Chrome Users: Click SETTINGS icon and select SETTINGS, then open Extensions, toolbar, search provider options, remove the SafeSaver Plugin if listed there. Make sure Google is set as default search Provider. 2, Removal tool It is always good and safe to use an automatic software to detect and eliminate viruses and malwares. The programs below are best for removing malwares. . Malwarebytes . Hitman 3, Delete it manually If the malware did not go away after uninstall procedure, try these steps. Please note, the manual removal method is a bit complex and it can go wrong if you perform its tasks incorrectly. It is advised to run an automatic virus removal software for safe and easy solutions. However, if you are good with Manual removal, do the steps below. Possibly corrupt registry keys:HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunHKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings “CertificateRevocation” = 0HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System “DisableTaskMgr” = 1HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system “DisableTaskMgr” = 1 Delete files: Run Wise JetSearch, fill in the keywords: Safesaver, search, and delete. Link to comment Share on other sites More sharing options...
