too many files running at the same time loging in very slow
internet Explorer
giving me problems... to many files are running at the same time
System root: C:Windows
Available physical memory: 5887 MB
CPU: AMD Athlon II X2 235e Processor
C: 683.54 GB
Internet Explorer: 11.0
Link to comment
Check the following topics:
How to speed up your PC by WiseCleaner_Admin
How to speed up a computer; speed up any PC or laptop (Part One) by Linkin
How to speed up a computer; speed up any PC or laptop (Part Two) by Linkin
Or try these operations:
1) If the warranty has expired, you could try to open your PC (first unplug it from the mains...!) with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor.
2) Open an elevated command prompt and type:
cleanmgr /sageset:1
Press enter, tick every option (or the options that you prefer) inside cleanmgr advanced menu, click ok, then type this:
cleanmgr /sagerun:1
3) Download adwcleaner portable (click) and run it.
4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder.
5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it)
6) Double left-click wisecare365.exe, click (top right corner) custom --> settings --> custom checkup, select/tick all entries (or the entries that you prefer), click save, click checkup, wait until the scan finishes, click fix.
7) Click the third tab at top: system tuneup
8) Launch sfc /scannow from an elevated command prompt (and report the result here)
9) Defrag your hard disks (it may take hours... Try first the OS partition only).
If you often get BSODs, skip this.
Keep us informed.
Link to comment
