Posted
sokhibas fájl van
translated from hungarian
Delete unnecessary files of drivers
there is a lot of bad file
Operating system:Microsoft Windows XP (32 bit) Szervizcsomag 3
System root: C:WINDOWS
Available physical memory: 2046 MB
CPU: Intel® Pentium® 4 CPU 2.80GHz
C: 50,05 GB
D: 182,83 GB
Internet Explorer: 8.0
Posted
1) Open an elevated command prompt and type:
cleanmgr /sageset:1
Press enter, tick every option (or the options that you prefer) inside cleanmgr advanced menu, click ok, then type this:
cleanmgr /sagerun:1
2) Download adwcleaner portable (click) and run it.
3) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder.
4) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it)
5) Double left-click wisecare365.exe, click (top right corner) custom --> settings --> custom checkup, select/tick all entries (or the entries that you prefer), click save, click checkup, wait until the scan finishes, click fix.
6) Click the third tab at top: system tuneup
