ysf Posted December 15, 2014 Report Share Posted December 15, 2014 when i open my computer msseces.exe is coming. (sorry about my english) screenshot msseces.exe - uygulama hatasi uygulama düzgünolarak başlatılamadı (0xc000007b). Uygulamayı sonlandırmak için Tamam düğmesini tıklatın. translated in english and possible exact english message msseces.exe - Application error The application failed to initialize properly (0xc000007b). Click OK to terminate the application. Operating system:Windows 7 Home Basic (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 3558 MB CPU: AMD A6-3400M APU with Radeon HD Graphics Drive Info: C: 450,53 GB Internet Explorer: 11.0 AppeptGause 1 Link to comment Share on other sites More sharing options...
xilolee Posted December 15, 2014 Report Share Posted December 15, 2014 Are you using MS essentials antivirus?Are you trying to install MS essentials antivirus?Are you already using another antivirus and aren't you trying to install/run MS essentials?Only if you are already using another antivirus and don't want to run MS essentials, you should disable MS essentials antivirus or uninstall it.If you want to disable it: open ms essentials, go to the settings tab, untick turn on real-time protection (recommended), click save changes. Looking forward for your kind feedback. Link to comment Share on other sites More sharing options...
ysf Posted December 15, 2014 Author Report Share Posted December 15, 2014 mr.xilo.İ HAVE MS ESSENTİALS AND ANOTHER ANTİVİRUS PROGRAMS. WHEN İ OPEN MS ESSANTİALS MSSECES.EXE İS OPENİNGTHANKS SOO MUCHOperating system:Windows 7 Home Basic (64 bit) Service Pack 1System root: C:WindowsAvailable physical memory: 3558 MBCPU: AMD A6-3400M APU with Radeon HD GraphicsDrive Info:C: 450,53 GBInternet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 15, 2014 Report Share Posted December 15, 2014 Have you disabled the real time protection in ms essentials? If you want to use ms essentials instead of the other antivirus, you should turn off the other antivirus real-time protection; or, if ms essentials continues to give that error even with that disabled, you should probably uninstall the other antivirus completely. Link to comment Share on other sites More sharing options...
